trying to connect a javelin stamp to an AF-P485
I am trying to connect a javelin stamp to an AF-P485 (RS232 to RS485 converter). The AF-P485 has 4 pins: A, B, +/- 5V. Does anyone know how I connect these 4 pins to the javelin stamp?
Post Edited By Moderator (Dave Andreae (Parallax)) : 6/1/2005 8:12:42 PM GMT
http://www.artech.co.kr/products_array/options/af-p485_big.htm
Neither of those 4 pins connect to the Javelin.
The DSUB9 connector pins 2 and 3 must connect to 2 Javelin I/O pins
via a RS232 level shifter like the MAX232 (or the Sipex237 on the Javelin demoboard)
Then you define 2 Uarts, one for receive and one for transmit.
regards peter
The DSUB9 (i.e.the RS232 side) is plugged into my PC's serial port.
The AF-485 will then convert the PC's 232 signal to a 485 signal that I will send out to a series of javelin stamps that are all hanging off of the 485 wires.
then all A's and all B's must be connected (these make up the RS485 bus).
Or use a Maxim MAX487 half duplex TTL to RS485 chip that connects
directly to the Javelin (this chip also has the A and
regards peter
