DC-DC Converters
I never used one in any application before so i'm a little lost.
I need a cost effective low power solution to convert 24v into 12v
I'm considering a +12V@10W from jameco (217032) but its pricy at $30. I dont really need 800mA, 200mA would suffice but the 5W version (216910) is $25 and its the same size
why are they better than regulators?
can they handle raw dc?
any help?
Byte walks into a bar and orders a pint. Bartender asks him "What's wrong?"
Byte says "Parity error." Bartender nods and says "Yeah, I thought you looked a bit off."
any help?
have a look at the LM2574 data sheet. This is a simple Switcher 0.5A Step-Down Voltage Regulator. It only requires a few external components: two el caps, an inductor, and a Schottky diode. They have thermal shutdown and current limit protection, and there are types available for input voltages up to 40, and up to 60 V, and for output voltages of 3.3, 5, 12, 15, and an adjustable type.
I'm using types for 5 V output in one of my commecial SX-based projects, and never had trouble with them. I have also designed a small PCB for the regulator (see the attached picture). Maybe, I should call it "Power Stamp" as its size comes close to a stamp
Greetings from Germany,
G
G
I'm glad that I could put you on the (DIN) rail
If you need one of my PCBs for evaluation (or maybe hundreds - I've go plenty of these), just let me know (g.daubach@mda-burscheid.de).
G
