BS2p24... full already!
Hello
Is there any way of adding addition eeprom space to the stamp modules for programming?
My first ever application I have written already exceeds the memory available.![rolleyes.gif](http://forums.parallax.com/images/smilies/rolleyes.gif)
I have trimmed it down to bare essentials, but as it is running an LCD screen, the data commands for the text are fairly hefty in using available memory.
Whats the next step up from stamps with regards to available programming space?
thanks
thanks
I believe the BS2p24 has multiple 2K segments you can use -- but you have to use them in 2K 'chunks'. It's not hard, but it's not trivial either.
Oh, and it is certainly possible to use an external SPI eeprom to store LCD screen data, and use the scratch-pad RAM to transfer the data to the LCD.
{$STAMP BS2p, prog2.bsp}
Save the program, exit the editor, then call it up again.· At the top of slot 0 you should see the two programs.
Not go to prog2 and write your additional stuff.· In slot 0, if you want to jump to slot 1, just write
RUN 1
In prog2, when you want to go back to slot 0, just insert RUN 0.
You can actually jump between slots, going to any point you want by using flags.· Flags are almost a GOTO.· Suppose in slot 0 you want to jump to a routine called "scan" in slot 1.· In slot 0, write
com = 1
RUN 1
At the very beginning of the slot 1 program write
if com = 1 then scan
When you have finished "scan" you can write RUN 0, or if you want to go to a certain spot, say "cont0", in slot 0, then at the end of your "scan" routine you write
com = 1
RUN 0
At the very beginning of the slot 0 program, write
if com = 1 then gosomeplace.
Set com to a byte in your variables declaration - this will give you 255 flags for each slot.
Is everything clear?
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
Jon Williams
