disabling programmability of Stamp
I have an application that requires the use of the built in serial port on a BS2p40 for serial communications with a PC. I would like to be able to enable/disable the ability to program the Stamp through that port, by means of a mechanical interface (switch, push button, etc.) In other words, I want to only allow the Stamp to be reprogrammed when a switch is thrown or a button is held down, and I need it to act like a regular old serial port the rest of the time.
Any suggestions?
Neil
Any suggestions?
Neil
Jon Williams
Neil
