loosing voltage on rb
hi guys,
for some reason unknown to me rb.4,5,6 drop to 4v with a 100k load, 2.5v with a 10k load.
ra.2,3(inputs) & rb.3,4(outputs) are the only io pins used in my application. the other 4 pins work fine and illuminate my led w/10k resistor just fine.
since rb.012567 have no pcb connection what might be causing this fault on pins with no pcb connection?
btw i tried 2 different sx28's
my code:
;================Device======================================================================================
device sx18l,oschs3
device turbo, stackx, optionx
IRC_CAL IRC_SLOW
reset start_point
freq 20_000_000
;================Start=======================================================================================
org 0
start_point
mov !rb,#$00 ; Set port B as outputs
;================Program Go!=================================================================================
main
mov rb,#$FF
go
jmp go
Byte walks into a bar and orders a pint. Bartender asks him "What's wrong?" Byte says "Parity error." Bartender nods and says "Yeah, I thought you looked a bit off."
my code:
device sx18l,oschs3
IRC_CAL IRC_SLOW
reset start_point
freq 20_000_000
org 0
start_point
main
mov rb,#$FF
go
jmp go
It sounds like it's setting the pull-ups instead of direction.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
"It's not getting what you want, it's wanting what you've got."
i found the problem....
nick said - "btw i tried 2 different sx28's"
code said - device sx18l,oschs3
i changed it to device sx28l,oschs3
and it works fine
i didnt realize that the line was so sensitive, shame on me
Post Edited (nick bernard) : 5/30/2005 3:33:41 PM GMT
