large motor control — Parallax Forums
large motor control
frosliefroslie Posts: 67
edited 2005-05-27 05:55 in Robotics
can anyone help with hopefully a simple motor control issue - i'm not sure where to begin.
I would like to control a larger motor - 12VDC or something appropriate.
I would like the the motor to be reversible and use a BS2 to ramp it and time out periodically.
the apllication will be an art work - I plan to automate tether balls.· I intend to place a motor at the base of the tether ball pole and run a shaft up the middle.· the top of the shaft will connect to the tether ball.· Ramping the motor should help the ball get into orbit; timing it out will stop it and cause the ball to wrap around the pole.
I am considering the motor mind b.· is there a better solution; am I way off the mark?
please aid me in this project.
    edited 2005-05-27 03:55
    You want to use the circuit Beau shows in this thread.
  • frosliefroslie Posts: 67
    edited 2005-05-27 04:16
    thank you, I will check it out.
  • Beau SchwabeBeau Schwabe Posts: 6,573
    edited 2005-05-27 05:25
    froslie,
    Please note, that the circuit that Paul refers to is a conceptual representation.
    You mention 12V motors.... what is the current rating? If you are unsure, can
    you measure the coil resistance without power applied to the motor(s)?
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    Latest Company News
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    Beau,
    I'm not sure. I am still in the process of determing the best motors to purchase.
    any suggestions on this are appreciated.· As I am an artist, much of my electric lingo has been self taught - the current rating will be the amps?
    please excuse my novice approach.
    aside: I have been using the BS2 to control servos and sensors for a a few years - simple circuits have been my focus until now. This forum is quickly proving to be very useful - thank you.
