RFID with a BS2pe
This is a followup to the BSE/EEPROM project I posted a few days ago.
This project uses a BS2pe and stores all records in the on-chip EEPROM slots 8 to 14.· Slot 15 is reserved by the program.· Each slot has 2048 bytes of storage which will hold 170 12-byte records.· This gives you a total record storage of 170 x 14 = 2380 records.· The attached sample program uses only slot 8, giving you storage space for 170 records, which should be adequate.· The program can easily be expanded to use more slots if you need them.
I did not include the Remote Operation in this program, but I am sure you will be able to add it if needed.· I·did add·one small feature - Menu option L.· This option lets you scan a tag without putting it in storage.·· It was designed to let you become familiar with the Reader operation before you start scanning records for storage.
The Program Notes are full of explanations, but should you need help please post your question to this thread.
Happy RFIDing
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
Happy RFIDing
Sid Weaver
Newzed@aol.com
zip
4K
I deleted the D option in the menu and the code definitions at the bottom of slot 0.· Now, when you execute the Search routine, the screen displays the tag ID, then searches for the Device code and displays all the information contained in the code definition.· Definitions are now located at the bottom of slot 1, beginning with Line 126.
Since the RFID Reader will be a permanent fixture on my desk, I have ordered a Super Carrier board for it.· At $19.00, you can't even get a comparable bare board for that price, much less one with all the parts on it.· I'll hardwire the LEDs and the Reader connector and dedicate it to RFID.··I can always remove the BS2pe for another project, then restore it.
Have fun!
Sid Weaver
Newzed@aol.com
