OEM bs2 trouble...
·I completed my OEM bs2 tonight. But when I try downloading a test prog into it. The basic stamp editor tells me that it doesn't detect a basic stamp..
· Any help would be greatly apriciated... thnak you, ·Duane.
1. Have you used your PC and serial cable to program any other stamps? Is the BS2 OEM kit the only stamp you have available to confirm that PC and cable are configured properly to communicate with a BS2?
2. Have you confirmed that you have power to the BS2 which in on the OEM board? Have you used a meter to confirm that you have 5volts on the BS2 IC on the OEM board?
3. Have you triple checked the orientation of the parts on the BS2 OEM board?
You may find it simpler to talk directly with Parallax support about this. They probably have a trouble shooting check list that they can walk you through step by step.
·· Please recheck that the transistors are all in the correct places.· There are 2 2N3904's (Q1 & Q2) and one 2N3906 (Q3).· Be sure these aren't switched, especially .· Also make sure the two capacitors (C2 & C3) are turned the correct way.· That is a common mistake.· They should be in line with the Resistor Pack (RN2).· And of course, always recheck your soldering and power supply.
csavage@parallax.com
I have put together many of kits before, this would be the first one( not a oem though). Lookes like I completly wasted this one..... Dang shame......
VDD TO VSS : 10.5k
VSS TO VIN : OPEN
VIN TO RES : OPEN
RES TO P0· : OPEN
RES TO VSS : 19k
\·· 5· 4· 3· 2· 1·· /
· \·· 9· 8· 7· 6· /
1 TO 2 : OPEN
1 TO 6 : OPEN
2 TO 3 : 4.6K
2 TO 6 : OPEN
2 TO 7 : OPEN
3 TO 4 : OPEN
3 TO 7 : OPEN
3 TO 8 : OPEN
4 TO 5 : OPEN
4 TO 8 : OPEN
4 TO 9 : OPEN
5 TO 9 : OPEN
6 TO 7 : SHORTED
7 TO 8 : OPEN
8 TO 9 : OPEN
The picture may help be of some help.
Have you pulled the two IC to check for bent pins on the ICs?
