Javelin not bidirectional
Hello,
I just switched over to Javelin programming. I installed the IDE from the CD and executed the HelloWorld example provided in the projects examples. I do not receive any terminal messages.
When I tried to set a breakpoint and run the debugger, I got the following message:
(Error IDE-0016) Unable to do line number translation for pc = 0.
When I double-click the error message (in the error window), I receive the following:
[noparse][[/noparse]Error] Unable to do line number translation for pc = %d.
[noparse][[/noparse]Description] The translation from the program counter to a line number could not be performed.
[noparse][[/noparse]Solution] The .jem file on the device is probably not current with the one in memory. Try downloading again.
Any ideas on what will solve this?
Environment = Win2000, no service packs, Pentium II
Thanks.
Thanks.
·· What happens if you re-download (re-program) the code?
csavage@parallax.com
·· Are you using a laptop or USB to Serial adapter?
Desktop with a serial connection via COM1.
·· Last question, what is the power supply?
· If in both cases you're using batteries, you really should try another set, or if you have it a Wall supply, since weak batteries could cause this.· If that doesn't work please contact us for an RMA.
Tried a fresh Duracell, out of the box - same results.
RMA? For the Javelin or CD? Is the error code IDE-0016 documented internally?
The CD version may not be the latest version.
regards peter
·· Peter sorta beat me to it, but I was going to ask what version of the IDE you have an suggest a possible upgrade to the latest version.· But contact us if this doesn't work.
Thanks for the suggestion.
Here's what I just did:
1) Uninstalled the Javelin IDE that came with the CD.
2) Downloaded and installed Javelin Stamp IDE Installer - Version 2.0.3.
3) Fired-up the IDE and opened \Projects\examples\manual_v1_0\HelloWorld.java.
4) Compiled and Programmed to Javelin.
5) Execution did not show the System.out.println() method's output in the terminal window.
6) Set a breakpoint on System.out.println("Hello World"); and attempted debugging.
Same error.
·· Please call us tomorrow at Tech Support.· We'll get that taken care of.
