help needed: maxstream and bs2's
I need some example basic stamp code to integrate my maxstream 900mhz systems.
I want 2 basic stamps to send simple 1 byte commands/responses to each other.
If someone has example code and is willing to answer a few questions , please respond
to dhusmann@ouhsc.edu.
I am willing to offer market value compensation for your time and effort.
Darrin
Darrin
I have some sample code I can send you. If you are more specific about the commands and responses I can help you more. Do you have any DS1620's? (temperature chips). I will send you an excellent program that transmits the temperature/s to a sperate computer and displays it/them on excel using STAMPDAQ. Simply mate your maxtream devices and it runs great. I used this as a class demonstration. I cannot Email you from this station, but I will Email you in the morning. As for the going rate of pay I cannot in clear consciense charge you for this. Is this for a class project?
Andrew
I used a similar wireless product with the above method.
as long as you have the wiring hooked up correctly between the
stamp and the maxstream it should just be sending/receiving serouts/serins to the maxstream/stamp
SEROUT PIN, Baud, [noparse][[/noparse]infobyte]
the baud you are going to have to figure out from the maxstream datasheet
it should also show you comms wiring.
DTQ
You are correct. Maxstream documentation is excellent and the SERIN/SEROUT commands are perfect for this.
Sofa
