very simple very stupid
Hi everybody.
can some of you explain why i'm not able to perform this very simple task?
DO
·Ore=1
DEBUG BIN16 Ore, CR
PAUSE 1000
Ore = (Ore+1)
LOOP
END
the debug windows give me always the same 0000000000000001 without incrementing the variable Ore???
thanks in advance for the help you will give me, i cannot come out of this very silly corner
Stefano
DO
·Ore=1
DEBUG BIN16 Ore, CR
PAUSE 1000
Ore = (Ore+1)
LOOP
END
Stefano
·· That is because in each pass through the loop you're resetting the variable Ore back to 1.· You should place the Ore = 1 before the DO section.
csavage@parallax.com
thanks again
