Wireless Serial Communications
I want to place data loggers in the field to monitor temperatures and pressures. These devices are designed to be hooked up to a PC from time to time via a serial connection for data downloads. I would like to take advantage of my wireless network connection on my tablet to collect the data when I am around the device and poll it. My tablet is running Windows 2000.
Is there a set of hardware that you would recommend that I could build and program to provide the wireless to serial communications?
I imagine there's no serial connector on that tablet. Must be a USB port though!
You could get a serial wireless system and then just put a USB to Serial adaptor on the tablet end and run a terminal program of some sort!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
What kind of range are you looking at for the wireless application? what moisture sensors are you using? I may be able to help you both. Stampdag is a great source for your application.
Sofa
1. Data collection and storage devices
ACR Systems, Inc. www.acrsystems.com single channel, multiple channel, specialized products
These devices communicate to a PC via serial communications. This would work, but I would like to get the tablet close to the device, initialize a serial download and collect the data via the 802.11b connection on the tablet.
2. Serial to 802.11b conversion.
B & B electronics www.bb-elec.com 1 port 802.11b to RS-232/422/485 Serial Server
I think this will work, but it is a bit pricey at $348.95 for basically duplicating the free capability of a serial cable.
http://www.siteplayer.com· is one that may work for ya
http://scmstore.com/english/IPControl/Programmable&Embedded/default.asp· is another that might.
as far as data storage....if you're sending it off the the PC, you don't need to store it....let the PC store the data.
Steve
this was the one I was trying to find!
Use a uMM Card for your data storage on site.
Steve
