Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
proteus VSM Stamp Basic — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
davids
64
2005-05-25 01:41
edited 2005-05-25 01:44
in
General Discussion
I have been using Proteus with the Basic Stamp modules to wire up my projects.
The frist one is a 74HC154 multiplexer, inwhich 16 leds flash one at a time.
The problem is that the Proteus software at run time says.
TXT
TXT
error.TXT
551B
error.TXT
551B
Parallax Engineering
14,406
2005-05-25 01:44
davids,
You will need to contact Proteus directly on this issue.
Their support can be reached through the following web site:
http://www.labcenter.co.uk/index.html?/products/vsm_overview.htm
csavage@parallax.com
Sign In
Register
to comment.
·· You will need to contact Proteus directly on this issue.· Their support can be reached through the following web site:
