Data to Memory Question...
OK,
I read in some of the PDFs that you can write to the EEPROM, your data that has been captured... but if you·record data frequently, then the write cycles would cause it to eventually fail over time.
What type of component do I need to record data without the increase in a chance that it will fail?
All help is greatly appreciated.
Joe
Joe
http://www.ramtron.com/doc/Products/Products_detail.asp?ID=41&FamID=1
The device behaves like a standard I2C memory and has a life of 10 Billion (with a "B") life cycles.· That's pretty impressive -- at that spec you could write to the same cell every second for over 317 years!· This thread will help you with the I2C stuff if you're not using a member of the BS2p family.
http://forums.parallax.com/showthread.php?p=466264
Jon Williams
Post Edited (Jon Williams (Parallax)) : 5/24/2005 6:29:03 PM GMT
Will this FRAM work with the "Homework Board"?
Joe
Jon Williams
