battery options for boe bot using bs2px
Hello, recently I replaced my bs2 with a bs2px. Once a few bugs on my part with timming and such everything seems to work fine. The only real trouble I have is that due to the higher power consumption with the bs2px, I am runnig threw batts real fast. Currently I use rechargable alkalines. With the bs2 I would get about 20-25 mins of run time. Now I am getting about 5 before I start getting brownouts. At first I thought the batts served there time, so I bought a new set. But I'm getting about the same time on runs. So I am intersted in learning on any sugestions along the lines of battery pack for the boe bot with a bs2px....
· I have the following items hokked up on my bot....
····························· (1) pind rangfinder
····························· (2) shard gp2d05 ir sensors
····························· (1) memsic 2125
······························(2) cont rotation servo's,
························· Also the bs2px on a boe board, and wheel encoders..
Thanx Duane
Thanx Duane
·· If you're running 4 batteries, this could be your problem.· Rechargeable batteries are only rated at 1.2V instead of 1.5 volts.· So you're already very near the brownout point of the Stamp Module.· Now with increased current consumption, you're likely browning things out more easily.· You could either another battery to the mix (For 5 total) or parallel another pack.
csavage@parallax.com
·· If you're sure they're rated at 1.5V, then adding one more battery may not be good for your servos.· Just add a second pack of 4 in parallel.· That will effectively double the current capacity at the same voltage.· Of course, you'll have to re-charge 8, instead of 4 batteries.
