Build A Better Mousetrap! — Parallax Forums
Chris SavageChris Savage Parallax EngineeringPosts: 14,406
edited 2010-05-17 02:19 in Robotics
Hello All,
·· This is actually an old project, but I’ve had a lot of requests to post it, so here it is.· If you're easily grossed-out, you may not want to read this part...But this is what got us started on building this project.· We used to live out in the country.· It was a nice area, and we lived in a small house.· Of course, being rural we had a mouse problem.· Normally we would stick a piece of cheese in a snap-trap and call it good.· We had mixed results.· Either the mouse would take the cheese and not set the trap off, or they'd get nailed and make a bloody mess out of the area where the trap was set!
·· One day (It was a hot one too) we came home and there was this awful stench coming from in the house.· The kind that makes you gag as soon as it hits you.· Upon entering the house we also noticed there were literally hundreds of flies, something we take great pains to get rid of.· My wife suggested that I check the garbage and the mouse traps.· The last one we checked was one we put in the back of our food cabinet where the mice have a little path between rooms.· As soon as we opened the cabinet, we knew we were in trouble!· Crawling around our cans & boxes of food were about 1,000 maggots!· We took a flashlight and looked in the back and there were the remnants of a mouse in the trap, crawling with maggots.
·· Suffice it to say, by the time we got done cleaning that mess up, we vowed to never go through that again.· Thus we set out to build a better mouse trap.· We decided the best way to handle this was by making 2 changes to the way a mouse-trap works.· First of all, we didn't think to check the trap because we were busy, and didn't even know we caught it.· Secondly, we needed to keep the mouse alive, so that it wouldn't attract maggots and such, and make a big stink.
·· Some answering machines have a feature that makes the machine beep every 10 seconds or so when there are new messages.· That way, when you come home, you're alerted to the fact that you have new messages.· We thought this was a good idea.· We needed to know when a mouse was caught, and catch him live, just in case we were gone for awhile, and so there's no bloody mess!· What better way to do this than with a BASIC Stamp?!?
·· The trap is built on a simple project enclosure you can buy for $5.00 from Radio Shack.· There is an opening at one end which the mouse enters the trap (Presumably to get the cheese).· If you place the trap along a wall where mice travel it will most likely enter the trap just out of curiosity.· We placed cheese on the far end of the box to increase the chance that the mouse would enter.· The mouse must completely enter the enclosure to get it.· About 2/3 of the way to the opposite end of the enclosure are an IR emitter and an IR detector.· They are mounted on each side of the box.· When the mouse crosses between them to get the cheese, he breaks the beam.· The BASIC Stamp is monitoring these sensors and detects this.· A servo is activated to swing a trap-door over the hole trapping the mouse, and an alarm sounds every 10 seconds to alert us that we have caught a mouse!· An LED also lights up.· Three mice were caught in the first week of use!
·· The better mouse-trap uses a surplus parallel LCD to display messages, which may seem a bit overkill with the Hobby Servo and other parts, but to me it was well worth the extra parts I had laying around the bench.· Below are a few pictures attached.· Being an older project I am still looking for the code for it.· Built this before I started organizing and backing up things!
csavage@parallax.com
320 x 240 - 19K
320 x 240 - 25K
232 x 209 - 11K
297 x 226 - 20K
243 x 221 - 12K
  • Kevin B SlaterKevin B Slater Posts: 49
    edited 2005-05-23 00:41
    Hey Chris,
    · Looks like a cool project, just curious though what was displayed on the LCD?
    Kevin
    edited 2005-05-23 00:59
    Kevin,
    ·· Nobody is beating a path to my door...I don't think it got that kind of coverage.· tongue.gif·· What was displayed is a good question though.· When powered on, the trap would display, "BUILD A BETTER" then "MOUSETRAP!" then "BY CHRIS SAVAGE."· Then it would say, "INITIALIZING..." at which point the door ould move into it's open position, regardless of where it was.· Then it would say, "AWAITING MOUSE" until one walzted into the trap, then it would say, "MOUSE DETECTED!" and the LED would light and the piezo would sound.· Below is a screenshot of it saying, "AWAITING MOUSE."
    320 x 240 - 20K
    edited 2005-05-23 03:47
    Okay,
    ·· I found a copy of the code, but it looks as though I was in the middle of re-formatting and updating it, and never finished.· But it should give you an idea what's going on.· Because it's been so long I can't even guarantee this code will work as it is, but it should.
  • Guenther DaubachGuenther Daubach Posts: 1,321
    edited 2005-05-23 17:19
    Chris,
    I already discovered the BETTER MOUSETRAP a while ago on your home page, and I still like this project.
    My concern is what happens when you are not at home for a while. Will the mouse die because he has nothing to eat (except the little piece of cheese), or will it get dizzy because of the beeper sounding every 10 seconds smile.gif ?
    Greetings from Germany,
    G
    edited 2005-05-23 17:22
    Guenther,
    ·· Mice don't seem to die very easily (Except when their heads are in the snap-trap), but I figure a week will still see it alive when we return.
  • cbmeekscbmeeks Posts: 634
    edited 2005-06-03 14:35
    neat project.
    Maybe you should turn it into a gas chamber? lol
    Seriously, what do you do with the mice you catch? My dad used to take his boot and crush their heads and I killed one with a blow gun once. hehe
    cbmeeks
    ps, darn weird first post on my part!
    edited 2005-06-03 21:40
    Hello,
    ·· The whole idea is to keep the mice alive.· My wife doesn't like me killing anything.· The mice are taken to a local State Park area and let go near a swamp area.
  • Fe2o3FishFe2o3Fish Posts: 170
    edited 2005-06-06 05:04
    Chris said...
    [noparse][[/noparse]mice]... let go near a swamp area.
    Reminds me of the urban legend story: The average cost of rehabilitating a seal after the Exxon Valdez oil spill in Alaska was $80,000. At a special ceremony, two of the most expensively saved animals were released back into the wild amid cheers and applause from onlookers. A minute later, in full view, they were both eaten by a killer whale.
    Sorry, couldn't help myself.
    -Rusty-
    Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
    **Out yonder in the Van Alstyne (TX) Metropolitan Area**
    Microsoft is to software what McDonalds is to gourmet cooking
    edited 2005-06-06 14:47
    Fe2o3Fish said...(trimmed)
    Chris said...
    That's the laws·of nature there.· Been around a lot longer than man.· tongue.gif·· In any event the Mousetrap is a humane way of catching any small animal.· I recall someone some time ago adapting the idea to a slightly larger scale for Racoons, Squirrels or something...In the field you could easily adapt the unit to dial your Cel-Phone or use a wireless device or some way of knowing from a distance that you have caught something, including a bigger/louder alarm.
    Post Edited (Chris Savage (Parallax)) : 6/6/2005 7:19:29 PM GMT
    edited 2005-06-06 19:03
    Hey,
    great idea - why don't you add one of the Ubicom IP devices - the mouse (or "catch anything") trap could send you an eMail on success. As an alternative, you could make it a WEB server allowing you to pop up an inventory list of caught items so far.
    On the other hand - when following the circle of life, you might consider to replace the BS2-powered mouse trap by a BS2-powered snake instead smile.gif .
    G
    edited 2005-06-06 19:22
    Guenther,
    ·· Your wisdom preceeds you...A snake would last a lot longer without food, so I guess it would be a good trade-off.· Have it so when the mouse is caught the door closes, but then a barrier opens between two compartments and the mouse, who was after food, now becomes food.
    ·· At least that follows the laws of nature.· Then I don't have to feel bad that I am killing a rodent who has trespassed onto my property.· Of course, my wife will find some fault in it.· I will leave it up to the people who use the project to modify it to their own liking.· Thanks for sharing the ideas!
    edited 2005-06-06 19:54
    Chris Savage said...
    Chris,
    I took your idea and made it into a·guillotine fashion trap.·· My version·is not as pretty as yours, but we did capture a small opossum with it.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/6/2005 7:57:26 PM GMT
    1800 x 1200 - 193K
    1800 x 1200 - 172K
    1800 x 1200 - 212K
    1800 x 1200 - 189K
    edited 2005-06-06 20:19
    Beau,
    ·· Awesome!· I knew someone had done something, but the ol' memory is getting slow.· Great job.· What did you glue everything with?· That stuff looks like the glue they use to hold cars together!· LOL
    edited 2005-06-06 20:33
    Chris,
    looks as if this turns into a highly sophisticated project...
    I think time has come to think about adding some fuzzy logic to the "trap controller" making the right decision on what animal (according to the rules of nature) should be released to eat the trapped victim. This model could even be extended: Let's assume the trap did not catch a mouse for such a long period of time that the snake gets really hungry. In this case, the "trap controller" should be smart enough to release a creature eating the snake just to follow the laws of nature. Sorry, I'm not a biologist, so I don't know which animal eats snakes but I'm pretty sure, some humans do - I'd better stop following such ideas right now...
    G
    edited 2005-06-06 21:39
    Chris,
    smilewinkgrin.gifI·think you are right about the cars - that great stuff is called "gorilla glue". It's like a gremlin, water is the catalyst.smilewinkgrin.gif
    Beau Schwabe
    IC Layout Engineer
    1800 x 1200 - 254K
    GLUE.JPG 254.3K
  • Microman171Microman171 Posts: 111
    edited 2005-06-07 07:20
    Beau Schwabe said...
    I took your idea and made it into a guillotine fashion trap.
    How did that work?
    1 + 1 = Window
    0............................................0
    0.(Microman171@hotmail.com)..0
    edited 2005-06-07 15:18
    If you look at the TOP image you se a "red" item... This is/was a screw driver that is pulled in or pushed out by the servo. On the BACKTOP image you can see a grove on the black plate (Plastic material similar to bake-lite) there is also a hole for the screwdriver aka "pulling pin" to enter. This keeps the guillotine door up until an ir sensor inside of the box senses an obstruction. Then
    momentarily, the pin is pulled releasing the door, and the pin is moved back into position. The pin moving back serves as a locking mechanism so the top of the door does not lift past the pin.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-06-09 18:07
    I actually had an idea years and years ago to attach a small laser to small "car-bots". These bots would be about the size of a golf ball and their sole purpose would be to seak and destroy roaches...lol
    your trap is a cool idea...and humane...well, unless you happen to catch a rat and a snake at the same time. Then, you took the fighting chance to live from the rat.... :-/
  • BeanBean Posts: 8,129
    edited 2005-06-09 20:13
    That glue is known as "polyurethan glue" (I know it's spelled wrong).
    And it's is some good sheee... Stuff
    Bean.
    "SX-Video·Module" Now available from Parallax for only $28.95
    http://www.parallax.com/detail.asp?product_id=30012
    "If you keep doing what you always did, you'll keep getting what you always got."
  • BatmanBatman Posts: 93
    edited 2005-12-26 02:29
    What items did you use to make the mouse traper (Chris Savage (Parallax).
    edited 2005-12-26 05:39
    Pretty much all of the information you would need is listed above.· Did you have a specific question?
    edited 2005-12-26 13:23
    Yes i wanted to know the specific items so i can try to order it from parallax.
    Like you used basic stamp and IR led and IR detector, but the question is which one?'
    There is alot of them out there in parallax·product.
    What basic stamp you use? BS1?BS2?HW?
    · Also about the servo, do i need same servo as you used?
    Post Edited By Moderator (Chris Savage (Parallax)) : 12/26/2005 5:31:08 PM GMT
    edited 2005-12-26 17:34
    A BS2 OEM was used.· No schematic is currently available as the device is being updated to make it much simpler.· It'd be better to wait for the new version.
    edited 2005-12-26 20:43
    ok!
    Can i use a BS1 OEM
    Soon i will rule the world with my new Batman Technology
    ·I Will Have So much Power that EVIL WIll Fear ME
    ·································· HO HO HO You Are Doomed
    ···································Laughing Out Loud·
  • ForrestForrest Posts: 1,341
    edited 2005-12-26 22:13
    The BS1 OEM was discontinued www.parallax.com/detail.asp?product_id=27295
    The BS2 OEM (kit) is on sale for $30 here www.parallax.com/detail.asp?product_id=27291
    edited 2005-12-26 22:26
    I·meant BASIC Stamp 1 Project Board, so i can start te project
    Stock#: 27112 Category: Boards-BASIC Stamp
    Price: $29.00
    Weight: 0.18 lb.
    Quantity: 1
    http://www.parallax.com/detail.asp?product_id=27112
    edited 2005-12-26 23:28
    Yes, you could easily use a BS1.· The BS2 was overkill even for this project.
    edited 2005-12-26 23:32
    your know about the OEM Basic Atom Module
    edited 2005-12-26 23:42
    This is a Parallax Forum for discussion of Parallax BASIC Stamps.· Please defer discussions of the BASIC Atom to other forums.
    edited 2005-12-26 23:49
    i didnt know i tough it was the same thing
