PSCusb Problems
Hello,
I am having trouble connecting a PSCusb to my Stamp2px. I am not quite sure what I am doing wrong. I can connect the PSCusb to my computer and control the servos just fine. But when connecting serially to Pin 15 of my S2px I get power and such on my PSCusb, but I am unable to control any thing. The code that I am using was taken out of the original PSC manual (RevB, ver2.2, page 5). I have not been able to find code for the PSCusb to control it with a stamp, so I just figured it would be the same as the original PSC. Am I correct, or will this only work with USB connections?
Thanks for your help!
Alex Burke
Alex Burke
·· The USB version of the PSC does work exactly the same as the original when connected to a Stamp Module.· The difference is that some Stamp Modules use different timing parameters for some commands.· This includes SERIN & SEROUT which are used to talk to the PSC.· Please see the Help File built into the Stamp Editor for the correct baud rate parameters.· The BS2 uses a different baud rate value than the BS2px.
csavage@parallax.com
Thanks for the tip. It works great now. I can not believe it was somthing that simple. I guess sometimes you can not see the forrest for all the trees.
Thanks again,
Alex Burke
