Yes, it should be possible. You'll need to configure the unit for TTL communications and connect your serial pin and ground to the display. Once that's done, try one of thse lines -- I'm giving you two lines because I don't know if the display uses inverted serial or not.
I have used LK-204-25 and LK-202-25 (both are serial interface) from MatrixOrbital. I believe that their products are fully compatible with BasicStamp. I can access all functions of the LCD from my BS2. If LCD2041-GW is serial interface, go for it !!
serout 0 ," hello"
SEROUT 0, 32+$4000, [noparse][[/noparse]"Hello, World!"]
If that doesn't work...
SEROUT 0, 32, [noparse][[/noparse]"Hello, World!"]
Note that the 32 in the SEROUT command is the baud parameter for 19.2K on the BS2.
Jon Williams
Dallas, TX· USA
Bronson Alex
tank you
Other samples for the stamp can be found at http://www.lcdforums.com/forums/viewtopic.php?t=937 .
Best Regards,
