NMEA GPS module
If anyone needs a GPS engine for their project I have a quite a few available.
See the following Link:
www.allsurplus.net/Axiom/
Questions will be answered if you use the "Contact Information" in the link.
Post Edited (Mike Cook) : 5/21/2005 6:32:23 PM GMT
Forgive me if I've missed it, but does it come with/does it need an arial/antenna of some sort?
Any idea on pricing? Are you in da USA?
Cheers
James
on your ebay listing with four items. If you select all items the
"compare items" does not work. Repeatedly.......
73
spence
k4kep
They sell 6 versions of SMA antennas, most are tri-band (GPS + 2 Cellular bands) but the cheapest is $13 with the cheapest active antenna being $20.
PS search "tri-band" to pull up thier tri-band antennas.
Post Edited (Paul Baker) : 5/27/2005 2:30:28 PM GMT
To keep "off topic" traffic down on the list, please use the "Contact Information" provided in the link or feel to PM me here. I would prefer you to use the "Contact Information" provided in the link, since this will get to me quicker and get you the information you need ASAP. I will answer all questions related specifically to this item off list.
However if the question is related to this item's operation with the Basic Stamp, then please post here. I'll reply·publicly here so the information can be shared.
Post Edited (Mike Cook) : 5/28/2005 1:10:59 AM GMT
I have made some minor modification to Jon's SIMPLE_GPS.BSP that is attached.
1. The Axiom receiver adds '.999' to the time field for 1000ths of seconds, which shifts the data down to different fields.
2. SIMPLE_GPS.BSP uses a Garmin custom sentence $PGRMZ which is not supported by the Axiom, if altitude is desired then the $GPGGA sentence contains the altitude field, I will try to find the time to add this to the program.
Attached is a screen shot of the receivers output of the debug window and a modified version of Jon's SIMPLE_GPS.BSP renamed to AXIOM_SIMPLE_GPS.BSP
"OEM NMEA GPS Module" Now available on ebay for only $19.99
Product web site: http://www.allsurplus.net/Axiom/
Post Edited (Mike Cook) : 5/31/2005 6:55:24 PM GMT
Thanks!
Dave
It's Only A Stupid Question If You Have Not Googled It First!!
I use a separate power supply, because I'm using my test fixture for the GPS module. The receiver and active GPS antenna can pull up to 180ma, so make sure that your BOE can supply that much current. If your running off of batteries that might be the problem.
Here's a shot of my setup, It's been running the code posted above for months.
www.allsurplus.net/Axiom/apps/GPS_BS2P24.jpg (warning this photo is about 1mb in size)
1. Using a separate power supply to power the receiver
2. Not using a BOE board but a Super Carrier Board, should be very similar
3. Stamp is a BS2P24
I have a GPS signal repeater, that's why I can have a GPS lock inside my shop, with the GPS antenna sitting on the shop bench, normally the GPS antenna should be placed outside so it can "see" the sky.
Sorry for the late reply,
Column #83: Where in the World is my BASIC Stamp?
http://www.parallax.com/dl/docs/cols/nv/vol3/col/nv83.pdf
Thanks for the reply!
Dave
It looks pretty straightforward. I am a little puzzled about how to connect the BS2 to the module (GPS Axiom sandpiper) in DGPS mode, is it as simple as moving that stamp input to port B of· the Axion GPS module?·
Thanks..............
Take a look at the links above for the Nuts & Volts article and program code.
While it is possible to use these with a BS2, all depends on your programming skills and techniques. They would probably be easier to work with on the BS24p or other models of stamps that have 'scratch pad memory'. Remember your dealing with variable length strings when interpreting the NMEA data.
Search the forums, or look in the files section of the old YAHOO group, there is an example program on how to extract time, from the receiver, using the BS2.
"OEM NMEA GPS Module" Now available on ebay for only $17.49
For more info in DGPS take a look at Trimble's site:
http://www.trimble.com/gps/dgps.html
Post Edited (Mike Cook) : 1/2/2006 11:51:38 PM GMT
Found some Active GPS Antennas in the surplus market:
http://www.halted.com/commerce/catalog/product.jsp?product_id=20182&czuid=1136325569296
Looks like it has an 'odd ball' RF connector, but at this price it seems like a deal to me!
I still find it amazing that module costs for DGPS are so high. they are completly out of my price range. I will stick with
GPS modules and the accuracy they provide.
http://www.wsrcc.com/wolfgang/gps/dgps-ip.html
My company's use of GPS technology is limited to the AVL industry, so we normally know what the item is we are looking for. The GPS information narrows down the location of the item we are looking for, so it can be recovered in a timely manor.
Post Edited (Mike Cook) : 1/3/2006 11:17:37 PM GMT
