Wire question
I need stranded #24 AWG wire (for a male to male db9 gender changer
cable, that I'm making.) I got (from Radio Shack) 2-conductor (I don't know how
many "conductors" I need.), 24-gauge, stranded,
speaker wire (Radio Shack part # 278-1301) I don't know much about
wire yet, so I don't know if it would work or not. I haven't opened the
package yet, so I can return it, if need be. Thanks!
Robotics
ro-bot-ics (noun)
the science or technology of robots, their design, manufacture, application, use, etc.
Robotics
ro-bot-ics (noun)
You can buy single strand from a place like Digi-Key by the spool in multiple colours. Or, go to your local burglar/fire alarm installer and buy (actually, he'll probably give you 8 or 10 feet just for coming through his door) a few feet of multiconductor stranded wire from him. A very popular size has 9 conductors plus a bare ground. Each conductor is a different colour. When individual strands are required, they can be easily pulled right out of the outer casing (up to six or eight feet, anyhow ) for use as hook up wire.
When you need small amounts of solid wire, buying a few feet of CAT 5 or CAT 6 Ethernet cable (the blue stuff connected to computer network cards) and strip out the pairs as required.
Cheers,
Tom Sisk
Robotics
ro-bot-ics (noun)
Thanx!
Robotics
ro-bot-ics (noun)
This comes in two different types, 'multistrand' with an RJ45 plug in each end, to connect your PC to a wall-socket, and
the 'single strand' type used 'in the wall' from that wall socket and to the main Hub/Switch.
(The 'single strand' is cheaper to manufacture, but doesn't take well to bending... )
Also, Cat5 isn't necessarily blue.
(It's most commonly gray)
Cat6, though, or is it Cat5e, is blue.
(Well, the single-strand cables I've seen are blue.)
Industrial supply store for wire. Any and every kind of wire you can imagine. I'd request a catalog, they are easier to use than the website.
Robotics
ro-bot-ics (noun)
