Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
AtoD Speed — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
General Discussion
AtoD Speed
Ultrasonicer
3
2005-05-20 13:42
edited 2005-05-20 19:59
in
General Discussion
Is there any way to speed up the sampling rate using the ADC0831 chip used in APPNOTE7 ?
Jon Williams
6,491
2005-05-20 14:19
edited 2005-05-20 14:19
You can't change the speed of Javelin methods -- you may look to your code to see if there is an opportunity to examine the device more quickly.
Jon Williams
Dallas, TX
USA
Peter Verkaik
3,956
2005-05-20 15:31
edited 2005-05-20 15:31
If you examine the read method, you see it calls calcMV(), which in turn
calls multiply().
If you stick to the raw data (i.e comment out calcMV() in read)
then you get a much higher sample rate.
I suggest you copy the read method and rename it to readRaw or something
like that and remove calcMV() from readRaw().
It is usually better to work with native units (raw data bytes) and only convert to human-readable
values (millivolts) when necessary, not for each read.
regards peter
Ultrasonicer
3
2005-05-20 19:59
Jon and Peter> We applied your suggestions and got an immediate 10x increase in sampling rate and are hoping to increase that still. Thanks again.
Sign In
Register
to comment.
Jon Williams
Dallas, TX· USA
calls multiply().
regards peter
