home alarm system
I'd like to program a stamp to operate as a home control system.· Either I can't find door/window sensors or else I am looking for the wrong thing.· It seems to me that I want the magnetic contact that sends the signal when it's broken or senses a low batter (like in a purchased system) as well as a receiver that will will be attached to my stamp and pick up the signal.
It's easy to find contacts but not the simple receivers, probably because the commercially available systems have them built into their consoles.
Or perhaps I don't need a separate receiver for each contact and something like the stamp RF module would work?
Any thoughts?
thanks
bob
Any thoughts?
thanks
bob
·· I have built several Micro-Controlled Alarm Systems, including using a BASIC Stamp.· I used door switches (Magnetic) from Radio Shack and PIR sensors I got from several sources.· Are you saying you want to do this all wirelessly?
csavage@parallax.com
Yes, I want to do it wirelessly.
When the magnetic contact is broken, how does that information get sent to the basic stamp?
what's a PIR sensor?
thanks
bob
·· I guess you'll have to research a system for handling the wireless part.· I am not familiar with a wireless solution that will do exactly what you want.· All the systems I designed and/or ever used were wired.· A system is less prone to false triggering, noise, or tampering if it's wired properly.
·· A PIR sensor is a Passive Infrared Sensor.· It's used to detect motion and/or body heat via Infrared.· They're generally used as a backup to the magnet switches or where a magnet switch cannot be used.· Most systems today have some type of these.· I have both the standard PIR as well as hybrid units which also employ microwave detection.
http://www.rentron.com/remote_control/RWS-434.htm
http://www.rentron.com/remote_control/TWS-434.htm
トヨタは すばらし です!!
Post Edited (Paul Baker) : 5/19/2005 12:02:01 PM GMT
