Good source for 'appmod header cable/pins' ?
I know Parallax has the app mod header connector for the PCB side, but is there a source for 'app mod cables' - or double sided header pins in dual rows (for the fabing of my own cable)?
Thanks!
Ryan
Thanks!
Ryan
·· The 20-pin header/extender is here: http://www.parallax.com/detail.asp?product_id=450-02003
As for a part for a ribbon cable, Digi-Key and/or Jameco should have something like that.
csavage@parallax.com
Yep Chris, I saw that, I was looking for header pins that are 'plug-in' length on both sides of the plastic...I can find straight header pins on Jameco, but they are 'short' on one side (the PCB side)- I was looking for 'double length' pins...
Thanks!
Ryan
You'll probably want the TSW or the HTSW series (near the bottom of the page). It's available in various length's - the .530 inch variety will probably work well, and the black plastic spacer is centered on the pin. Note on most headers, you CAN slide the pin in the plastic (though it requires some force).
