Making the LCD display the DEBUG? — Parallax Forums
Steve-OSteve-O Posts: 8
edited 2005-05-18 22:17 in BASIC Stamp
Just wondering how you go about this
  • NewzedNewzed Posts: 2,503
    edited 2005-05-17 19:06
    How do you go about what?????
    Sid Weaver
    Need a bezel for your LCD?
    Newzed@aol.com
  • dandreaedandreae Posts: 1,375
    edited 2005-05-17 19:13
    Basically you take the variable that you are reading in the Debug terminal use the SEROUT command (provided you are using a serial LCD) to serout the variable on the LCD.· It's a simple code:
    x var byte
    X=65
    SEROUT 0,9600,[noparse][[/noparse]SDEC X]··· 'sending the value 65 to the LCD
    DEBUG DEC X,cr················ 'displaying 65 in the debug terminal
    Dave
    Dave Andreae
    Tech Support
    dandreae@parallax.com
    www.parallax.com
    Post Edited (Dave Andreae (Parallax)) : 5/17/2005 7:17:00 PM GMT
    edited 2005-05-17 19:14
    Steve,
    ·· Your post is rather cryptic, but if you have a Serial LCD Display, and you want to DEBUG to it, you simply SEROUT to the LCD pin the text/data you want.· You can use all the same formatters of the DEBUG command, however the one difference is SEROUT requires the [noparse][[/noparse] & ] around the data.· Otherwise they're virtually the same output formatting.· If you have a parallal LCD, it will be a bit more difficult, but can be done.
    csavage@parallax.com
  • Steve-OSteve-O Posts: 8
    edited 2005-05-17 20:41
    Thanks guys...sorry about the lack of info...I hopped on here on my way out the door.
    Steve
  • edited 2005-05-17 21:24
    Go to the Parallax Serial LCD product page:
    http://www.parallax.com/detail.asp?product_id=27976
    Then, download and review this document (at the bottom of the page):
    Stamps in Class Serial LCD Tutorial (.pdf)
    It demonstrates several different ways of taking Debug Terminal informion and displaying it on the Parallax Serial LCD.
    edited 2005-05-18 20:30
    I apologize for not mentioning this earlier, but I have a parallel LCD. It's the one that came in the StampWorks kit. Again thanks everyone for the help.
    Steve,
    ·· You will have to write your own output routine and send text to it one character at a time.· There is circuit and code for this in the StampWorks manual, a free download in PDF format from our website.
