Hello, I was wondering if nayone had any experience with using a sonar rangefinder to map rooms. I'd love to see some code examples to study... thank you all very much _Duane
Ok that should be alot easier to do, you would keep an array of variables, you would take the distance measurment, fill in the variable corresponding to that angle, rotate, repeat until the polar plot is filled in.
