pump controled airflow
I am working on a prototype for a kiosk for children to hear what the·call of a parasaurolophus (dinosaur) would sound like, as predicted by various science types. The idea is to have a hand pumped bellows control the air flowing through the sound making device, and the out the head cavity of a cast reproduction of a parasaurolophus head- so that it "breaths" out through the nostrils at the same time as making this sound. Kids seem to like that sort of thing. At first I thought that I could just link the output of the bellows to the control handle of the compressed air system, but that didnt pan out. I was wondering if you think it would be possible to take a dc blower, and hook it backwards to the output side of the hand pumped bellows, then read the slight voltage ( ac most likely) that would be induced in the coils of the blower, send that voltage to STAMP to be analyzed, then have STAMP control the voltage (and therefore intensity) of a much larger blower according to the input signal, that outputs through the nostrils of the dino. so it would be something like:
Bellows blow air into the blower, thus producing low voltage ac which, is sent to analog to digital converter, which is sent into STAMP, STAMP reads the voltage and outputs to a voltage regulator, which controls the much larger blower according to the intensity of the bellows.···· Sound good. Too much? Insert easier solution here:
··········· I have a question, do you need the hand pump in the design? Or could it replaced with a different type of physical control?
Stephen Swanson
Technical Support
sswanson@parallax.com
Post Edited (Stephen Swanson (Parallax)) : 5/16/2005 10:29:02 PM GMT
Just put a microswitch at the air output of the bellows...but a large "wing/fin" on the microswitch so that it catches air and closes. Then just look for that 'state' with the stamp and use the stamp to do the rest of the control.
Maybe get a small compressor w/ reservoir. Then you can fire a blast of air out the nostrils immediately followed by the noise and then another blast of air!! Like a snort!
Not sure if this is how the animal would actually do it....but most animals today will snort when confronted (before attacking anyhow).
You can use the stamp to control a pneumatic valve that would open and give you your blast of air.
It is a bit of a pain to have a single compressor/reservoir for one small attraction....but if it's there, then you can run other attractions off of it too! All with their own regulators/solenoids.
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
If I were to write up code for the IR idea, I would set it up that the stamp counts the number of pulses on the detector signal line using a timeout value around a second, then send this value (raw or processed) to the device that acts upon the information, and repeat the process.
MEarly another idea to confuse you with!! haha
BAsically, the temperature will cool (think wind chill) as air passes it....the faster the air, the lower the temp dip.
Now, you would still want a reference sensor so you could say, IF tempsensor1 - tempref1 is less than 10 (saying that the temperature dips by 10deg) then do something....
You can get digital temp sensors (DS1620 I think) that you won't need an A/D converters for...but they are a tad more pricey.
You can then look at ranges of temp changes. If the dip is only a difference of 3...then do this...if it's more than 3 but less than 10..then do this....if it's more than 10...then give'er some good stuff!! lol
Steve
My head is spinning from this one... the "device that acts upon the information"- can that be the STAMP ? or would I need an external processor? Or do you mean the blower?
(Im sorry I'm not very quick to respond to the posts here, I kinda have to check the forum every few hours @ work, but I do appreciate all the help I find here!)
··········· In that case since you want to keep the pump, your setup should work as you mentioned above. You will just need to do the following. For the dc blower you will want to hook it up to a voltmeter the + and – pins and measure the voltage (it should be DC if it is a DC blower). Once you get the max output of the DC blower you will then be able to determine if you need to cap the voltage at 5vdc. Once you have that done you can then feed that in to an A/D converter connected to the Stamp.
Stephen Swanson
Technical Support
