How to speed up SX-Key uploading
I am working with XGameStation using both parallel port and SX-Key.
I have found that using SX-Key is much slower than using parallel port when uploading code.
A program that can be uploaded in 5 seconds using the parallel port takes abut 2 minutes to load with SX-Key.
Is there any setting to set COM port speed or anything to speed up things ?
Inaki.
Inaki.
to my knowledge, the SX-Key device uses a fixed serial communication rate which can't be changed. Therefore, I don't see a chance to increase the speed of serial programming the SX chip. On the other hand, I have never experienced programming times at about 2 minutes to program an SX with the SX-Key. To my experience, the duration of programming depends a bit on the total code size but even large programs are transferred within - say - less than 20 seconds.
Did you download and install the most recent version of the SX-Key IDE from the Parallax site? This might help. You should also check with Task Manager while programming an SX with the SX-Key if there are any other applications or processes that request a high degree of CPU usage which most likely will slow down the data transfer.
Greetings from Germany,
G
·· The slowdown problem might also explain his problem with programming through the parallel port.· Perhaps he has a virus, or Adware/Spyware problem which is affecting the timing of things?· I have seen this happen before.
csavage@parallax.com
If you read carefully my first message on this thread I say that am I able to upload the same program in 5 seconds using the parallel port while it takes about 2 minutes to upload with SX-Key.
Said that, I must add that I am very careful with security issues. I would not say it is anything related to a virus or spy-ware. It seems to me that there is patent difference between using parallel and Sx-Key at least on the XGS board.
I also do have an XGS board here. When this is set to SX-Key programming mode, the two relevant SX pins (OSC1 and OSC2) go straight through to the SX-Key pin header, so I can't imagine that any of the XGS board components cause such a slow-down.
If you have the cance to program an SX device on another hardware platform (e.g. an SX28 on an SX-Tech Board) try to program a device there, and see how long it takes. As I said before, 2 minutes are way above the serial programming time I have ever experienced with the SX-Key.
BTW - did you set the SYSMODE switch on the XGS board to "KEY" when using the SX-Key?
G
On the XGS board I set the SYSMODE lever to Sx-Key position when programming. The I set it to RUN and it works as expected.
So, it seems to work, the only problem I see is speed.
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
http://metroidclassic.com
DMCA Sucks
RIAA Sucks
G
