Super BOE-BOT code
Noah,
Saw your robot project post, looks some interesting code was used, hope you got a good grade. I am posting the code I used, plus a write up on the wiring. Hope the wiring description will help.· The main things are the mian BOE has a Bs2sx chip and the secound BOE has a Bs2 chip. Also to get all the boards working, all the boards, the· RC receiver· and Servos must have a common Vss(-).· I hope these with be of help to you or anyone else interested. I would also be interested in the code you used. If anybody has any questions, Iwill be glad to try and answer them.
Joe Fishback
MAIN BOE BROAD
Bs2sx Chip
P0······· orange············· P0 thru P4 are from Gazbot circuit board
P1······· yellow
P2······· green···
P3······· blue·····
P4······· purple
P5······· red·················· signal to P5 on second BOE board
P6······· white··············· signal from RC receiver Channel 2 inline with 220 ohm res.
P7······· white··············· signal from RC receiver Channel 1 inline with 220 ohm res.
Vss(-)· black··············· to black on channel 1 & 2 of RC receiver
Vss(-)· purple(2nd)····· to second purple on Gazbot circuit board
Vss(-)· black··············· to Vss on second BOE
Vdd(+)blue(2nd)········· to second blue on Gazbot circuit board
SECOND BOE BOARD with AMPLIFIER APP. BOARD
Bs2 chip
Vdd(+) red·················· to "B" input (+) on RC receiver
Vss(-)· black··············· to "B" input (-) on RC receiver
Vss(-) black··············· to· Vss(-) on main BOE board
Note : pull down resister circuit use with P4 and P5
P4······························· to white signal line on rifle firing servo
P5······························· to P5 on main BOE board (signal object detected )
Joe Fishback
MAIN BOE BROAD
Bs2sx Chip
P1······· yellow
P2······· green···
P3······· blue·····
P4······· purple
Bs2 chip
Holy moly, that is some tricky coding! Short and sweet the way it should be. Nice of you to share with the rest of us. I like the combination of two chips working together. I am considering taking two Javelin chips on a tank mod and combining them for my next project. I LOVE the nerf launcher posted earlier by bishop. For my next project I would like to have one of the Javelins handle the autonomous navigation with the compass and sensors while the other transmits and receives via an RF mod. I am imagining a Mars Rover type project capable of imaging and object retrieval. I want to program it to "explore" my garage on its own and bring back something.
Here is a link to my COOL Autonomous Robots webpage:
http://www.ecst.csuchico.edu/~noahs/224/ all of which use a plain old BS2.
Any suggestions as to how I could shorten my object retreiving source code would be much appreciated.
I will be the first to admit my source code is somewhat sloppy and could be made more efficient. I need to free up some more space for calculating the return angle. The one time out of ten it fails is due to a misalignment in the return trip. This could also be due to the degree I am tilting the compass as the crawler hops along. I have been looking into a Hitachi digital compass also offered through Parallax. I am wondering if anyone else has had any luck with it?
' PIN#--HARDWARE CONNECTED
' 0--SRF04 SONAR INITIAL PULSE
' 1--SRF04 SONAR ECHO DETECTOR
' 2--CLAW OBJECT DETECTOR
' 3--LEFT CLAW ENCODER
' 4--RIGHT CLAW ENCODER and SPEAKER
' 5--DIGITAL COMPASS APPMOD
' 6--GROUND DETECTOR
' 7--(empty)
' 8--(empty)
' 9--(empty)
' 10--(empty)
' 11--(empty)
' 12--LEFT LEG SERVO CONTROLLER
' 13--RIGHT LEG SERVO CONTROLLER
' 14--LEFT CLAW SERVO CONTROLLER
' 15--RIGHT CLAW SERVO CONTROLLER
Great idea btw. im using an rc control unit for a robot project of mine, and its harder than i thought.
WANNABE UBER GEEK
____________________________________
MAD SCIENTIST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
