Common Ground and Voltage In
Everything that I have read says that a motor should have its own power source, but I thought I read in another post that you still have to have a common ground. Could someone tell me that if I have three different ciruits interconnected, but using different Power source, do I tie all three into the same common ground?
Thanks in advance,
Stephen
Thanks in advance,
Stephen
·· If the devices are isolated, either mechanically or optically, then the power supplies don't need a common ground.· An example of optical isolation would be if you're using an Opto-Coupler or an SSR (Solid State Relay).· Mechanical isolation would be if you're using a Mechanical Relay.· In these cases the device being controlled doesn't need a ground reference with the Stamp because the control circuitry isn't electrically connected to the controlled device circuitry.
csavage@parallax.com
I believe I understood the explanation that you and Chris gave. I also came across a fairly good explanation in a robotics book that I picked up. I attached a schematic that they provided in the book, which shows the use of two different power supplies. Could you let me know if it (the schematic) is correct?
During my prototyping I'm going to use one of the Garmin handheld GPS units. I wasn't sure if anything special needs to be provided for it, as it has it's own power supply (and ground) via batteries. Since the BS2p24 will be receiving SERIALIN data from the GPS, I didn't know if that would cause any problems. I know that when I go with an OEM GPS board, I would just provide power via the electronics circuit (at least I believe that is right).
Stephen
·· In that circuit, the motors would be getting the voltage from that connector, but apparently unregulated.· The electronics would be getting the power from the other connector, though through a 7805 regulator.· It looks okay.
