LED LIGHTS for the garden
hello,
i am looking for White LEDS or RGB LEDS that i can use for in the garden, to create a "Romantic" lighting.
I know that there are bright white LEDS and RGB Leds. (in fact you can by these light plug and play in the hardware store, but not cheap)
So, has somebody already tried something like this (power supplys , humidity influence, use of 1 sx28l for dimming and switching from color to color , controlling the dimming with use of the 24 volt line??,cooling, ...)
I am guessing for 1 light i need : 4 LEDS on a print that is applied by a 24 volt DC input power supply ( the farest point in the garden is 20 meters).
So comments are welcome
Kurt
Kurt
· You might try here.
················· http://www.superbrightleds.com/
· They have all types of LEDs, they even have RGB LEDs in one package.· Click on the LED button and then scroll down and you will see the RGB LEDs listed.
Hope that helps.
Kevin
