Extending a Thermocouple — Parallax Forums
Brian GrimmBrian Grimm Posts: 7
edited 2005-05-16 17:57 in General Discussion
Greetings all.· I'm working on a project to control a small kiln.· Because of the temperature range, I'll be using a type K thermocouple.· The one I've purchased is 8 gauge, bare wires with ceramic beads for insulators.· I've seen thermocouple extension wire, but is it required?· Something I read (of course, I can't find it now) led me to believe that I can use stranded bell wire as long as it isn't exposed to the heat.
Anyone with experience out there?
Brian, N7QJB
    edited 2005-05-16 14:53
    Hi Brian,
    A thermocouple is formed at every transition between dissimilar metals. So a connection from type K thermocouple wire to copper bell wire will form two junctions. However, it you keep both of those junctions at the same temperature (inside a little junction box?) the error will be minimum. The temperature of the kiln is so much higher than room temperature and a few (~10?) degrees of error are probably no sweat. Ideally, the type k extension wire would come all the way back to the meter or controller, forming a reference junction there that the meter can measure and compensate. Omega Scientific has lots of good reference materials and tutorials online.
    Tracy Allen
    www.emesystems.com
  • Brian GrimmBrian Grimm Posts: 7
    Thanks Tracy. I've been looking through the materials at Omega, but couldn't find a good answer about the extension wire. However, I do remember seeing a diagram discussing the effects of multiple junctions. I'll have to go back and read that again.
    Thanks again,
    Brian, N7QJB
