Hamamatsu Photoreflector
how can I check that my Hamamatsu Photoreflector is still working and has not burnt or is not bad.
トヨタは すばらし です!!
yes it worked in the circuit then it stopped, I though loose connection but no,
agian I have to make another circuit again it worked but stopped later on
Whats going on I want to figure out
The spec sheet shows the pins for the "pulse input" that should force the output low on the 5588 model.
トヨタは すばらし です!!
