XGS: Cannot communicate with device
I am trying to connect the XGS IDE with the board but I get the error: Cannot communicate with device.
I have checked that I/O addresses are right. The board is plugged, using the provided parallel cable, and it is powered on.
I am using the PAL samples.
The board does work wit the Pacman sample that comes pre-recorded.
Anyone has had the same problem ?
Thanks.
Inaki.
Thanks.
Inaki.
·· You might want to check your LPT port settings.· On most motherboards there are several options for the mode of the port.· Also, does it communicate through the SX-Key interface?
csavage@parallax.com
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"Great people talk about great things, average people talk about average things, small people talk about other people."
What should happen if I use a PAL TV with PAL crystal on the XGS but the game is coded for NTSC ?
I have solved the parallel problem changing Bios Setup to EPP port mode. Thanks Chris for the comment.
I have checked also the SX-Key plugged on COM1. The "Programming..." windows shows and keeps forever on the display. The progress bar runs up to 100% but then it hangs there.
The window refuses to be closed even when I click the close button. Is there anything to set ? For example, I could not find a place to select COM speed. Note that programming does work, that is to say, the program RUNs fine once programming reaches 100%.
Also I have noticed programming with SX-Key is much slower that using the parallel cable. Is there any way to speed up things and prevent programming hanging up ?
Thanks.
Inaki.
you should download the latest version of the SX-Key software from www.parallax.com/dl/sw/sx/SX-KeyEditor3_1.exe which fixes the problem with the lock-ups.
Greetings from Germany,
G
It works fine BUT, the first time I try to compile, I have to go to the tools and click APPLY.
Then, it will work.
I think it's a strange bug.
cbmeeks
