Which STAMP DOS Editor?
Hello everyone!
I'm just getting started in STAMP programming and already I'm having issues. I have an old 486 laptop that I bought an ebay for $40 and I think it should be enough to talk to a piece of hardware. My "real" laptop is a 2.8g powerhouse and doesn't have a serial port. I don't want to get the USB->SERIAL adapter either because I've had problems with those in the past. This little DOS laptop really should be enough and I'm comfortable using DOS.
Anyway, that said..
I see 6 different versions of the DOS STAMP EDITOR on the CD. But I don't know which one to use and I can't find any references to the DOS editors on the PARALLAX web site.
So which version of DOS EDITOR should I use?
STAMP.EXE, STAMP2, STAMP2E.EXE, STAMP2sx.EXE???
Help...
thanks
jac.
Anyway, that said..
Help...
thanks
jac.
·· The DOS editor is no longer supported.· If you have a copy of the old DOS editor you could use it to program older Stamp modules, but the newer chips require the Windows version of the editor.
·· If you need a reliable USB to Serial converter, we sell one that is compatible with the BASIC Stamps.· Please see the link below for more information.
http://www.parallax.com/detail.asp?product_id=800-00030
Post Edited By Moderator (Aristides Alvarez (Parallax)) : 5/15/2005 12:44:47 AM GMT
Stamp.exe - BS1
Stamp2.exe - BS2
Stamp2e.exe - BS2e
Stamp2sx.exe - BS2sx
Stamp2p.exe - BS2p24 / BS2p40
You can't edit multiple files at the same time for the Stamps that have multiple program spaces and you lose the PBasic 2.0 functions, but other than that, they're OK. (I sometimes use a HP Omnigo 200LX DOS based PDA to program on)
Start it by writing 'Stamp2 filename.bs2'
Then press F1 to read the help and to find out about the function keys.
Just remember, when you quit this editor it will NOT ask you whether or not you want to save your file.
