Signatures — Parallax Forums
Signatures
MacGeek117MacGeek117 Posts: 747
edited 2005-05-17 13:00 in General Discussion
I have tried to upload a picture as a signature, but no dice. Could I have some help?confused.gif
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
  • Aristides AlvarezAristides Alvarez Posts: 499
    edited 2005-05-13 05:05
    Go to "Control Panel" on the top of the page and then select "Edit Profile."
    At the bottom of that page you have your signature. Just copy the image you want to add and paste it there.
    You can test the results in the Test Forum.
    Aristides Alvarez
    Education and Technical Support Manager
    aalvarez@parallax.com
    Parallax, Inc. www.parallax.com
  • MacGeek117MacGeek117 Posts: 747
    edited 2005-05-13 16:40
    I can't get it to paste. Here is the image:
    bugg
    Boe-bot: $229
    Toddler: $249
    315 x 141 - 9K
    1.jpg 9.3K
    edited 2005-05-13 16:49
    Bugg that's a large picture to want to attach to the end of every message you post...Don't you have something smaller?· Also, do you understand the circuit?· It could be done with one AND gate, instead of two NAND gates...
    csavage@parallax.com
    edited 2005-05-13 16:56
    Chris, yes, yes, but NAND gates are cheaper and I like circuits that look complex but really aren't! Also read the book Build Your Own Robot!
    bugg
    Boe-bot: $229
    Toddler: $249
    edited 2005-05-13 17:43
    bugg,
    ·· I guess to each his own.· Of course, 74LS00 Quad 2-input NAND gate is 22 cents and 74LS08 Quad 2-input AND gate is 26 cents.· That's 4 cents difference.· As for adding complexity, as a beginner I would tend to think simpler if I were you.· Some day you might have this overly complex circuit that doesn't work, and nobody will be able to help you because it's unusually complex.· Just trying to save you form that...You may appreciate the AND circuit more when you're left to hand-etch your boards and have to route all those extra signals.· tongue.gif
    edited 2005-05-13 20:21
    In regards to your original question about pics in sigs, you may have noticed me playing around with it in the test forum. To place a picture in your sig, you use the image button in the sig edit dialog, now here the catch, it must be a picture that is accesible via an url (http://....), you can make the picture an url by posting the picture as an attachment as you did in the earlier post, click on the picture and copy the URL into the dialog box for the picture in the sig editor. I changed my sig over to your picture for this post to show that it can be done. If you right click on the pic below and bring up the properties of the·pic you'll see it pointing to the same location as your posted pic. Oh yeah, and convert your image over to gif format, the gif version will·be a much smaller size, hence it will load faster and consume less of Parallax's bandwidth.
    Thanks for the help! It is probobly to big.
    bugg
    Boe-bot: $229
    Toddler: $249
