MAFS Translator?
I want to make a translator to convert the signal of a chevy mass air flow sensor to the signal output by my stock sensor.· I also wanted to make it adjustable to compensate for larger injectors.· I know that the voltage from the sensor will have to be converted from analog to digital then run through an equation and then converted to a voltage for the ecu.· The range of voltages to measure and convert is 0-5V with a hopeful resolution of about .01V.·· My question is do you think that this is possible with a stamp module or will this be too much for a stamp to do?
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
