Motor Mind project failing PLS explain
My motor mind c board appears·to not·work.· The problem is that the TM (BS2 serial data to motor mind·c) and (FM motor mind c serial data to BS2).· TM works sending data, but the FM doesn't send back data.· If anyone can tell maybe why this is the case.
The code I use is the code is the datasheet (figure 6)which I·have changed just one part (IF IN14 = 1 THEN .........) to (IF IN7 = 1 THEN...........),· but motor mind still doesn't send data.
Maybe some·code is missing from the program?
Jon Williams
Dallas, TX· USA
addr var byte
leng var byte
cksum var byte
dat1 var byte
Jon Williams
Dallas, TX· USA
Post Edited (davids) : 5/10/2005 4:29:28 AM GMT
Jon Williams
Dallas, TX· USA
Jon Williams
Dallas, TX· USA
Not true Jon! [noparse]:)[/noparse] I do that when appropriate (now)-
Ryan
Jon Williams
Dallas, TX· USA
·· It appears that you have at least 3 different threads on this issue in different forums.· Please do not cross post.· You're making it difficult to help you by doing so.· Please see the original thread for what may be your problem.
csavage@parallax.com
Thank you all
David
