I am still in the conceptual stage. Essentially I need to run two shafts in one direction for 10- 15 seconds, and some time later run them back. While running, they need to always be within several revelutions of each other. Motor type and electronics are to be specified. My experience is more in the heavier industrial controls and not much in small robtics.
Hello, ··········· The BS2 would be good for this, on the Motor mind C you would be able to control both motors directly but you would have to program the stamp to read some type of sensor to check the speed and then adjust the Motor mind c output to the motors.
Or you could use two Motor mind B’s they both have a tech in built. Which would allow you to set the speed, you want and then the Motor mind b would adjust the output with relation to the tech reading. To find out more about the Motor mind b please visit. http://www.parallax.com/dl/docs/prod/datast/MotorMindB.pdf
Stephen Swanson
Technical Support
Parallax, Inc. sswanson@parallax.com
Post Edited (Stephen Swanson (Parallax)) : 5/9/2005 8:48:05 PM GMT
Jon Williams
Dallas, TX· USA
Jon Williams
Dallas, TX· USA
Stephen Swanson
Technical Support
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"Great people talk about great things, average people talk about average things, small people talk about other people."
