Jump Problem
I'm having a small problem.· If I write:
(lines of code followed by[noparse]:)[/noparse]
put Line1, "RB.6 = ", dis, "· ", chg
gosub @show
goto main
It compiles perfectly.
If I write:
put·Line1, "RB.6 = ", dis, "· ", chg
gosub @show
goto @P1_Start
' Page 1 Code
Page_1:
· ADDRESS $200
P1_Start:
goto @main
I get an error "Unable to·assemble due to errors in source code".
Why?
Sid
gosub @show
goto main
If I write:
gosub @show
goto @P1_Start
' Page 1 Code
Page_1:
· ADDRESS $200
P1_Start:
goto @main
Why?
Sid
Jon Williams
Dallas, TX· USA
Post Edited (Jon Williams) : 5/9/2005 3:10:03 PM GMT
Please post the complete code that is giving you the error.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"I thought I was wrong once...But I was mistaken [noparse];)[/noparse]"
with 'goto main' it compiles OK.· Beats me.
Sid
Sid Weaver
Need a bezel for your LCD?
Newzed@aol.com
You have too much code in the page zero. And it's running into page 1.
SX/B now handles all that code page Smile. Just remove all those ADDRESS lines that you had to use in version 1.0. Now you can just keep writing code until the whole chip is full.
Bean.
www.sxvm.com
"Great people talk about great things, average people talk about average things, small people talk about other people."
When I try and compile it with either line I get the assembly error. However, you didn't mention the specific error messages that SASM gives you when you compile the SX/B program. It really helps when you provide all the information that is given to you by the IDE when soliciting help. In your program, the SASM error is:
Overwriting same program counter location
This is the big clue that tells you what is going on. Your program is too big to fit in the one page of the SX chip. I am guessing that you wrote some smaller section of the code, assembled and tested that, and then did a big cut and paste-a-thon which subsequently refused to assemble.
BTW, are you using the new 3.1 version of the SX-Key IDE?
Thanks, PeterM
I am using IDE V2.03.04.· Is that the latest?· Haven't used my SX/B in quite awhile.· Been so busy with other things.
How can I tell how much memory I have left?
Sid
Sid
Since we just updated the SX/B compiler and help file today, you'll need to update it after you install the 3.1 IDE.· You can get the SX/B updates from the sticky at the top of this forum.
Jon Williams
Dallas, TX· USA
2.03.04!!! Yikes! Go, my friend, and download 3.1 pronto! Lots of bug fuxes, inmprovements, etc since the 2.0 series. Jon provided the URL in the post above.
Thanks, PeterM
How can I tell how much memory I have left.· Per Bean, I deleted all the ADDRESS statements from my template - there is no page 1, no page 2, nothing but my program.· Have I gone astray somewhere.· I've written a lot of PBasic programs and what I have doen't look like 2K to me.
Sid
You cannot compare SX/B to PBASIC in language use -- it's an apples and oranges comparison; though using subroutines as I've suggested gets you closer. In the BASIC Stamp, the code for RCTIME is in one spot, and the tokens are setup to call it. In your program, you've got the code for RCTIME 16 times -- that's how you blew through 2K of code in such a hurry. What you may have to do is study the RCTIME output and write a custom function that will allow you to pass a pin number to it as the BASIC Stamp version of RCTIME allows.
Jon Williams
Dallas, TX· USA
rb0 var RB.0
rb1 var RB.1
and so on, then wrote:
for ix = 0 to 7
HIGH rb(ix)
That didn't work - I got an error message
"expecting 0 to 7"
I just had an idea - what if I wrote:
pin con RB.0
gosub time
pin con RB.1
gosub time...............................
time:
high pin
pause 8
rctime pin, 1, dis
return
Would that work?
Sid
Looking at your code, though, I did find a place where you can get some code savings: your PUT statements.· For example, you do this:
· PUT Line1, "RB.5 = ", dis, "· ", chg
... 16 times.· I think you could fold that into your Show subroutine by using parameters to pass the port ("B" or "C"), the bit ("0".."7"), and your dis and chg values.· Give this a try:
Show:
· temp1 = __PARAM1···· ' port
· temp2 = __PARAM2···· ' bit
· temp3 = __PARAM3···· ' dis
· temp4 = __PARAM4···· ' chg
· PUT Line1, "RB.0 = ", dis, "· ", chg
· PUT Line1(1), temp1
· PUT Line1(3), temp2
··FOR ix = 0 to 15
····GET Line1(ix), char
··· SEROUT So, Baud, char
· NEXT
· RETURN
You would call Show like this:
· Show "B", "5", dis, chg
Remember to declare your subroutine so that you can place it anywhere in the code (and drop "GOSUB").
Jon Williams
Dallas, TX· USA
