The SX/B program I'm working on is generating a number larger than 255.· How do I handle this word-sized variable?· I've tried an array but couldn't make it work.
Jon, I'm trying read RCTime, so I don't what the values are going to be, and I can't read the result into two variables.· Would I be better off just using a byte variable, and changing the resolution to 4 or 5 or whatever to keep the value·less 255?
Not necessary, Ken -- one simply needs to adjust the Resolution parameter. This was added specifically to address this issue. If one needs additional resolution the SX/B output of RCTIME could be modified to handle multi-byte vars (you have to adjust the code and delay timers).
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
Dallas, TX· USA
Post Edited (Jon Williams) : 5/8/2005 9:20:28 PM GMT
Sid,
If you need more acuracy, you can do RCTIME with a resolution of 4 or 5. Then if the value returned is low, then do RCTIME again without the resolution value (defaults to 1).
Bean.
"SX-Video Display Module" Available Now.
countLo··· VAR··· Byte
countHi··· VAR··· Byte
Jon Williams
Dallas, TX· USA
Sid
Sid
Jon Williams
Dallas, TX· USA
Jon Williams
Dallas, TX· USA
Bean.
www.sxvm.com
"I thought I was wrong once...But I was mistaken [noparse];)[/noparse]"
