Shut down problem
I am running into a problem with my BS2. I can write code to it and run the function but if I shut power off to it, the program goes haywire and won't read the code properly unless I re-program it. It this common? Just wondered if there was a cure for this..
thanks..
Jeff
thanks..
Jeff
As for how to fix it I have no clue, I've never seen a stamp do that.· Is there any other details you could give about what you do when you power down your stamp?
Chris
Jeff
Did you try doing a reset after powering up?
DTQ
Jon Williams
Dallas, TX· USA
I do not have a WRITE command in the code but I am trying to figure out why it won't hold the programming. I am putting this sign I have made into my slot machine for a display and don't want to worry about having to reset every time. that would be a drag.
I am using your tutorial code Jon as a guide and when try to use mine I get a bunch of scrambled LEDs. Just pushing forward to get it right...
thanks for the replies
Jeff
Jon Williams
Dallas, TX· USA
2. Power problems can give these symptoms. The fact that "Reset" does nothing makes this more likely.
3. I don't think a 500 mA power supply is good enough for all those LED's -- but since the 7819 'strobes' the LED's, perhaps it is.
4. It IS possible to 'wear out' the EEPROM by using 'WRITE' statements under program control -- but this would cause a verify failure, not the symptom you are describing.
5.· Are you using the EEPROM to store some of the data?· It is also possible to over-write your program tokens, and not realize you've done it (unlikely, but possible).
csavage@parallax.com
higher output under less than rated load.
Now I have to get the chips to flow the scroll instead of each having its own display scrolling each character. Did that make sense?
ok cya
Jeff
·· I thought that might be it.· Glad you got it figured out.· Some computers have issues with taking over the COM Port when it's idle.
