How to implement BS2 OEM application?
I am looking at a possibly building· 6· devices built around a BS2. What little bit of reading I did leads me to believe that a minimal
implementation·consists of an EEprom for program storage, BS2 interpreter chip and a resonator. I am guessing I could program an EEprom stick it into the board with the interpreter and the resonator based with the assumption that it would·simply run the program from EEprom on power up. Will this work?··
Jon Williams
Dallas, TX· USA
Chris I.
Jon Williams
Dallas, TX· USA
For mass production, for $300 to $500 you can buy stand-alone gang eeprom programmer hardware, which will program 8 to 16 eeproms in a single pass. This sound like overkill for your 6-units, though.
And you can always use the BS2 OEM board for debugging, too.
