Problem with output voltage range...
I am attempting to use a sx28 to communicate with a playstation controller (spec here)but I am having this weird problem where the output Voltage range seems to vary based on the average logic value of my output. It works like this, if the output logic level is mostly High the output seems to range from -5VDC upto 0VDC (where logic High equals 0VDC). On the other hand, if the output logic level is mostly low the output range is the standard 0VDC to 5VDC. To further complcate thing if I output a %50 duty cycle square wave, the voltage varies from -2.5 upto 2.5 (2.5 = Vdd/2 in this setup). This is all happening with the 28 plugged into the demo board with the SX Key used to program and run the chip. this happens with or without the playstation controller plugged in so I don't think it has anything to do with that end of the hardware. Does anybody have any ideas about what would cause such an effect and more importantly, what can be done to correct it so that the output always varies from 0 to 5V (vdd).
thanks
Ben
thanks
Ben
I don' t know how you would be negative voltage otherwise.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"I thought I was wrong once...But I was mistaken [noparse];)[/noparse]"
Jon Williams
Dallas, TX· USA
