The difference between parallax servo controller serial and USB??
I order two PSC(serial)·module from parallax, but·mistakely it became PSC(USB). could anyone·tell me if both version is interchangeable or not.
for my application I need BS2 connect to Two PSCs daisy chained together, that·same as the figure 6 of the parallax servo controller documentation.
but·I could not find any infomation about that in the documentation of PSC USB version.
Sorry about that.
··········· The USB PSC, has been designed to be controlled from the PC USB or the BASIC Stamps® through the three pin header on the board with the same commands used on the PSC serial version.
Stephen Swanson
Technical Support
sswanson@parallax.com
(Or, is there a functional·reason (e.g., is the USB's command syntax different?) why those examples from the SERIAL PSC documentation were omitted from the USB PSC documentation?)
Peter R
··········· That is correct the (serial/USB)·boards have the same firmware. The Daisy chaining of these units would also be the same. The commands can be found in the serial version of the PSC manual.
Stephen Swanson
Technical Support
