Attn: Entire SX family unsecure to light attack!
Hello,
Recently, I was investigating the security of the SX28 device from Ubicom.· I admired the floor plan of the layout where-as there was a ram and a flash area to the left with pure-logic all over on the right (no sign of microcode anywhere unlike a PIC).
While the security/config fuses were no so obvious without delayering, I found that the by simply focusing light over the fuse area, you can dump any locked SX device!· In order to do this, the attacker must know how to open your chip up which is tedious.· Once opened, the attacker needs to only focus a halogen lamp into the corner of the die.· Leaving the light on, he tells the device to read out.· 3 of 5 reads will result in the true code of the SX device!@!#@!
Coder BEWARE!· This is no lie!
This is an unexceptable result.· Most chips act funny under high intesity light from your obhective and you can turn the light down and all is well.· In this case, the chip unlocks itself and returns the correct user-code from inside if you just put a dimmed light source in the corner of the die!
You don't know me from Adam but I eat silicon for my meals.· I normally post on Avrfreaks and to be honest, I love the AVR but I study all kinds of micros not just Atmels.
Good day!
It is possible that a transistor connected to the fuse subcircuit but not protected by the metal 3 layer is causing this problem, if the logic which drives the security setting signal is being thrown into an artificial state, the fuse could be bypassed. If this were the case then it would fall into the "unanticipated design flaw" catagory.
Post Edited (Paul Baker) : 5/5/2005 11:39:01 PM GMT
This could be the downfall of the SX because exposing the bare die is nothing unusual for persons in my line of study. This is something Sergei Skorbotov would have loved to have added to his paper he recently released. Looks like he never caught this because he rated the SX with decent security (and it has decent security since the fuses are buried under M3 and out of plain sight. It takes a wet-etch with HF to remove M3 and only then if you understnad semiconductors would you spot them.
My reason for asking is this: People who have been working with SXs and who are concerned about their products being duplicated, are going to want to know if they can migrate to PICs and feel safer. I would like to have some idea of what might be a reasonable answer.
James Newton, Host of SXList.com
james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
SX FAQ / Code / Tutorials / Documentation:
http://www.sxlist.com Pick faster!
New or old PICs are not very secure.
We also know that PICs are vulnerable in other ways (and I have heard that from any number of sources) so we don't really have anywhere to go.
That leaves the question: What can we do about it? Probably nothing, but here is an idea that may or may not be useful:
- I believe you can use an external osc that does not depend on drive from the SX, (I haven't done it personally) and it may be possible to blow the bond out wire on the OSC2 pin by applying a quick pulse of high voltage (this has been done to the programming pin on some PICs) which renders the SX unable to report its programming via that pin. I would guess that if the SX has been opened up, it would still be possible to make contact with the OSC2 pad on the silicon, but maybe that is not so easy?
And finally there is the real question: Do we really care? As Sherlock Holmes said: "What one man can invent, another man can discover." The best defense is to produce the next generation code while your competitors are stealing the last generation.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"I thought I was wrong once...But I was mistaken [noparse];)[/noparse]"
Jon Williams
Dallas, TX· USA
Just an FYI to fellow engineers out there.
Jon Williams
Dallas, TX· USA
Obviously this is something that could be resolved by some kind of armored packaging technology that would destroy the chip before access is gained.
I suspect it could be done if necessary, but I personally don't have so much invested or to hide in a SX chip. I am here to learn from others. It is a fellowship, a community.
In a hostile world, you are on your own. You have to think of everything. There are no friends, no teachers, no mentors. A Tibetian rinpoche once commented that paranoia is highly intellegent - but not truly wise.
Scenix may be wiser than this little scare.
I hope you get my drift. It is something like, "We all live in a yellow submarine."
G. Herzog in Taiwan
Post Edited (Kramer) : 5/16/2005 3:27:45 PM GMT
