air ride system
Being low on funds and just finishing a visual basic.net course, i was turned on to the idea of using a BS2px inorder to control my air ride and support other functions(clock, accelerometer.....but nevermind those) what i am looking for is a way to interpret data from pressure sensors. i was thinking that i could use 4 input pins, reading pressure senders(transducers) to continiously scan with PULSIN. would this work? i am looking to get data from 4 corners and the tank at no more than 300 psi. for this, i need to find some reasonably priced pressure sensors in the 0-5v range that will not break with sudden pressure change(and are low in cost). i was unaware if i need analog or digital sensors, so if you could help, it would be appreciated.
also, i was wondering what kind of transducers i would need in order to drive 12 volt relays. also, i want to know if this store.earthlcd.com/s.nl/sc.7/category.297/it.I/id.315/.f can accept signals from the stamp, and if it can send data back from the touchscreen if used as buttons... i know this is a lot. thanks
I think you'll find you may need an A/D converter otherwise!
We buy our atmospheric pressure sensors from these guys and here's a quick check on a model that might suit you!
http://www.setra.com/tra/pro/p_te_205.htm (An A/D converter would be need as full scale would be 5V...).
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
