Demo program (poll.bs2p)
davids
·I'm be playing around with the poll.bs2p demo program, but if I change pollmode 10·to a different decimal constant such as·8...15 ·the program doesn't work.· Then I remove it the program works again.· PLS can someone point the main reasons behind this problem.
··········· This would be correct. If you change the poll mode the stamp will act differently and may not work as the Poll.bsp is setup as for.
Example: If you set the poll mode to 11 this tells the stamp to RUN (jump to another bank of memory). ·What mode are you wanting to use?
Stephen Swanson
Technical Support
sswanson@parallax.com
but changing poll mode 11 will if sent low trigger an event in another progam slot.
