Pbasic prog question.
I was wondering if it was possible to call a subroutine within a subrouitine? As an example .. If I had a sub routine named IR: and bassed on different conditions I might want to call RIGHT:, or LEFT: ..... thnanks again _Duane
Since there is no PBASIC "CALL" instruction, I'l presume you're speaking about GOSUB here. The answer is yes, you can have nested GOSUBS. Here are the restrictions on GOSUBS which can be found in the PBASIC Help File (which see):
Nested Total Number of
GOSUBS GOSUBS
BS-1 4 16
BS-2 4 256
Just make sure all of your GOSUBS and RETURNS are properly paired.
Bruce Bates
On the BS2, you can have up to 256 total GOSUB destinations.
And, you can nest them 4-deep. Thus your 'main' loop can call GOSUB Sub_A, which calls Sub_B, which calls Sub_C, which calls Sub_D. If Sub_D then calls anything, you may have messed up your return stack.
Note, with only 2K of code space, and 26 bytes of variable space, this does not tend to be much of a limitation.
