Help electricians !!!
This may sound a little weird but just bear with me here·.........
I am doing a college project. I am using minute electromagnetic activity in plants (thats right as in organic plant)·or other organism·to trigger off midi in a computer via an atom chip attached to a circuit board. Basically it goes like this:
·plant > atom chip > midi > computer
Obviously I need a positive and negative attached to the plant or no potential difference· will be created (the positive is the input of the preamps)
My question is this·:
Do I earth the plant just to the negative inputs of the preamps , or do I connect all the negatives (including preamps,plant, batteries)·to the·0 volts ( vss ?)·on the circuit board ?
If anyone wnows what im talking about help would be very much apreciated !
Gus
Gus
I would put a copper rod into the soil, and use that as my ground. Moist, fertile soil has pretty good conductivity.
Then, I would tie the grounds -- Vss, Pre-amp, plant, and batteries -- to a single point so they all share a common reference.
You can probably amplify the signal from the plant with an op-amp or two.
The rod I was speaking of (and it could just be a length of 8-guage solid copper wire) was to be put into the soil the plant was planted in.
And 'earthing' to Vss would be fine.
