highbyte lowbyte — Parallax Forums
highbyte lowbyte
waltwalt Posts: 27
edited 2005-05-01 23:41 in Robotics
· What does highbyte and lowbyte mean or do in a program for BOE BOT.
  • KenMKenM Posts: 657
    edited 2005-05-01 17:02
    A word variable is 16 bits or two bytes. Each byte being 8 bits.
    Define a word $F0 or....
    %1111111100000000
    The high byte is %11111111
    The low byte is %00000000
    k
  • waltwalt Posts: 27
    edited 2005-05-01 19:48
    · Thank you that makes sense. Sure is nice to have you guys out there
    edited 2005-05-01 22:54
    ·why would you have to use this after pulsewith as in .
    ···· serout sdat, baud+$800, [noparse][[/noparse]"!sc", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, cr]
    This is a line from a program for a servo controler. In the program the veriable·for pw is a "word" please remember I am new at this.
    · ch·· VAR·· byte
    · pw· VAR·· word
    · ra·· VAR··· byte
    Walt,
    ·· Serial data transmission is done one BYTE at a time.· Since you're trying to send a Word, you must send it one BYTE at a time.· In this case, LOWBYTE then HIGHBYTE.
    csavage@parallax.com
